V8 throttle cable mounting
Discussion in 'General Maverick/Comet' started by smegnl, Jan 26, 2020.
  1. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    1) I assume I am missing a plastic clip or something that keeps this cable in the pedal?
  2. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    soooo...... Do i just shove this V8 cable in and put some screws in it???
  3. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I took the one off the i6 cable
  4. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    last question...How high did you mount your v8 pedal? The bottom hole on the bracket lines up but not the top. The position of the pedal seem ok, if not a tad high. The top looks lined up with the hole for the throttle cable.
  5. 71gold
    yep...the same one I was looking for.
  6. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    FYI looks like your clip is still there just pushed into the hole. 82622D5D-7A11-4B02-8219-DC4B6AB298DB.jpeg
    BBMS18 and Craig Selvey like this.
  7. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I think that is a separate bushing. The other one was smaller.
  8. William623
    William623 Member
    Orlando
    No that should be the correct one.
    Acornridgeman and BBMS18 like this.
  9. Acornridgeman
    Wisconsin
    I agree with William ……….. pull that out of there and hope it is not smashed.
    BBMS18 likes this.
  10. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Cool, thanks ill do that tonite.
  11. William623
    William623 Member
    Orlando
    Most of the time they are fine, only had one really jammed in there before and it still worked. Just have to be really careful pulling it out.
    BBMS18 likes this.
  12. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    is this how this goes?
  13. yellow75
    Tillamook Oregon
    Yes that is the way it is on both my cars
  14. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    thank you very much
  15. William623
    William623 Member
    Orlando
    1EEAFED0-A455-46C3-87A7-732E881D9940.png Had to dig through some really old photos of mine lol. But you can see it in this photo.
    smegnl likes this.
