v8 throttle cable
Discussion in 'General Maverick/Comet' started by classic ccg, Apr 19, 2013.
  1. classic ccg
    ringgold GA
    72 maverick
  2. Craig Selvey
    I could not get your picture to open. Can you post it here?
  3. 71gold
    you will need the pedal also...:yup:
  4. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    I don't think it's a 6 or 8 cylinder issue. I think some years had the "slot" type (for lack of a better term) and some had the eyelet/pin type. It looks like you need a pedal setup for the eyelet/pin type.
  5. CaptainComet
    The early style pedal ran from 70-72, and then they changed the end on the cable for 73-on.
    The crimped-on end on the earlier one can get pulled off over time. The later design seems more durable.
    Another way to tell early vs late is that the early ones only have one bolt attaching it to the firewall and later ones have two.
  6. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    One thing is that you can use the I6 cable on the V8. You will just have some extra cable.
  7. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Not sure it's that cut and dry...I have a '71 and a '72, and they both have the eyelet style. OP just needs to be sure he finds the right pedal style before he goes through the trouble of removing one only to discover it's not the correct one. The bolts attaching it may be a better indicator than year :huh: Perhaps it was build plant specific or something.
  8. 71gold
    yep...that's it...:D
  9. classic ccg
    ringgold GA
    72 maverick
  10. classic ccg
    ringgold GA
    72 maverick
    i pulled it and that's how i fond out
  11. classic ccg
    ringgold GA
    72 maverick
    dose any one have a 71 or 72 they may want to trade? for two 73and up?
  12. Craig Selvey
    All you need is a gas pedal to fit the top cable. I have one. Email me DIRECTLY (see below) if I can help.
  13. 71gold
    because of this....when I pull cables from donor cars, I always get the pedal too...:yup:
  14. classic ccg
    ringgold GA
    72 maverick
    Man that's sucks lol oh well I won't do that again lol thanks for all the fast hel
    I p guys
