V8 Troubles
Discussion in 'Technical' started by Scraperondubz, Jul 26, 2008.
  1. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    i have a mav with 1985 HO v8 two barrel. ith car is having trouble. idles fine but when i put in drive it has no power.wont take off i can barely make it pass 35mph. any ideas. the car has a new fuel pump. car ran fine untill pump was replaced
  2. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
    Is the pump delivering enough fuel? Did you accidentaly pinch on the lines going to the pump?
  3. Scraperondubz
    Oakland, California
    MAVERICK
    yeah pumps fine, replace the line as well
  4. don graham
    What kind of pump is it? Mechanical or electrical? If it is mechanical did it get the arm on the fuel pump put in right?
  5. yellow75
    Tillamook Oregon
    Why was fuel pump changed in the first place? could problem possible be a plugged fuel filter? The e85 fuel is causing havoc with fuel related items.
  6. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    I have a 86 HO and had trouble getting the right manual pump for it. One the arm was the wrong pitch and it pumped to much and took out the diaphram in it. Sounds like a fuel problem but, you didn't change plugs & wires did you? If so make sure you have in correct fire order, a HO is the same as a 351 winsor. Good Luck!
