...vac. system mod.
Discussion in 'Technical' started by 71gold, Feb 28, 2009.
  1. 71gold
    73' A/C car vac. system.
    my car had 2 vac. ports on the...heater water valve...
    i replaced it with a...1 port valve.
    on the vac. digram they show...partial vac. and full vac., all on the same...brown hose..
    being i have 1 port i would like to do away with the...Purple and the Green hose and let the Brown be full vac. to the valve. does anyone see why that wouldn't work?
    ...Frank...:Handshake
  2. Dave B
    Hmmmm, and I was trying to figure out how to move the vacuum can to the inside of the car, under the dash.....
  3. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    frank i dont see why it wouldnt work... because the only difference was the vacuum switch... but that is only useful with a partial opening valve... i say it will work :yup:
    go for it
  4. 71gold
    thanks Nick...:Handshake
    do you know why they put the partial and full vac. on the same hose? :yup:
    NFF...(y)
  5. nickmav70
    Dallas, GA
    1971 Ford Maverick
    :huh:no not really lol... i just know how it works... not why... catch me up
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I have been running with a single line for awhile. All it does is open the valve up more when the heat is in a specific position, ( I cant remember what postition I am at work right now so I couldnt tell you but I believe it is defrost.) otherwise I have had no problem running the $19.00 valve instead of the $89 one.:cool:
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    does the water valve switch have anything to do with why one is called full and the other partial? When I T'd it off I had no problems like everyone else.
  8. nickmav70
    Dallas, GA
    1971 Ford Maverick
    alright this what we have come up with... the 2 port valve has 2 diaphrams in it and on line opens the partial then when you cut the vacuum to the other it opens the other to give you a full open valve... basically just an educated guess
    :tiphat:
  9. 71gold
    Dave,
    i have mine behind the plastic fender liner on the pass side....i can get you a pic. if needed...
    it's a plastic ball w/oneway valve in it...CHEBY
    ...(y)...
  10. Dave B
    Hmmm, too bad I already bought a reproduction can from NPD. But thanks for the idear!!
  11. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I'll take one please.
  12. 71gold
    I'll be right back...:outtahere:
  13. Dave B
    Waiting.........:bananaman
  14. 71gold
    NCIS got in the way...:tiphat:...
  15. Dave B
    Very Nice!! (in my best Borat voice)
