vacume/electrical
Discussion in 'Technical' started by Leadhead, Apr 24, 2002.
  1. Leadhead
    Leadhead New Member
    Eagan MN
    1974 Comet
    ok so call me stupid but I'm in need of some good vacume and electrical diagrams for a 74 comet with a 250. Swapped engines but I'm having extra vacume lines from engine to engine. plan is to pull all lines off of original and just rerun them on the new but I didn't label very well where lines go....ok so only labled one line :) and help would be appriciated:confused: Heeellppp!!!
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Check this out....
    Go to maverickgrabber.com At the home page (after images are preloaded) go to tech articles and then wiring diagrams. It will help you a lot. I think it says that they are for 70-73 Mavericks, but I still feel that they would help you get most of the tubes and wires hooked up. Hope this helps. If you want a set of wiring diagrams for yourself, ebay usually has some posted. Good luck. If you have any more questions please don't hesitate to ask. Thanks.
    -Corbin
  3. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Hey tuped!! Is your swap like for like? What year? I may be able to help you out.
  4. Leadhead
    Leadhead New Member
    Eagan MN
    1974 Comet
    ok yeah...so I didn't mean letterally call me stupid butthat's ok...probly deserved in this instance. I swapped the original I6 250 ('74) for a I6 250 from a '79 monarch...only differance is the carbs....
  5. Mavaholic
    This is a diagram I did from my 76 with 250.
  6. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Here is a copy from the book for 250 non/air cond.[​IMG]
  7. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    250 vac system
  8. raydenaomi
    raydenaomi Member
    Louisiana
    1976 Ford Maverick
    does anybody have a diagram on how to install carburetors on a 76 mav? I dont know where all the hoses fit. I think i'm missing a hose on the egr valve. cant find a repair manual anywhere
  9. rthomas771
    Wiring diagrams... http://1bad6t.com/Maverick/repair/chassis_electrical_05.html
    Its according if you have an automatic or manual transmission, A/C or non A/C and other emission components. You have 6 different '74 vacuum diagrams to choose from... http://1bad6t.com/Maverick/repair/74Vac.html
  10. rthomas771
