Vacuum lines
Discussion in 'General Maverick/Comet' started by maverick656, May 16, 2015.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    What Vacuum lines on my 75 250 can I trash? they are kinda just in the way. And do I have to keep the PCV lines to the carb? Thanks
  2. rthomas771
    You need the vacuum line going to the distributor's vacuum advance from the carburetor. Also vacuum line going to the transmission if it's an automatic. If you have AC then you need to keep the vacuum line going to the AC vacuum canister. Yeah...keep the PCV vacuum hose.
    Rasit and 71gold like this.
  3. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    But everything else can go? I don't have a.c. by the way
  4. Krazy Comet
    If you have state emissions testing, the vac lines are probably going to be necessary to pass a visual...
    PCV is a good device, for a street engine should never be disconnected...
