Valve Adjustment
Discussion in 'Technical' started by Mikei16, May 31, 2013.
  1. Mikei16
    Mikei16 New Member
    New York
    I have 1973 with 250 6 cyl. I wanted to adjust the valves, I was told that some engines had no adjustment any ideas?
    Thanks
    Mike
  2. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Your engine does not have adjustable rockers. I you have to get the adj rockers off a 144 or 170.
    Check FordSix.com or Classic Inline for more info. You are staying with the six, you need "The Ford Falcon Six Cylinder Performance Handbook" http://classicinlines.com/products.asp?cat=73
    Rick
  3. Mikei16
    Mikei16 New Member
    New York
    Thanks Rick,
    Rick, if I were to install an aftermarket cam would I buy the solid lifter cam or hyd cam setup?
  4. 71gold
