I am getting ready to change out the valve covers, gaskets and bolts. The bolts that are on there now are crappy. I have Ford GT 40X aluminum heads. Do you recommend that I use aluminum valve cover bolts or will standard or stanless steel be fine. Don't want to mess the heads up. Thanks!!
Since you have aluminum heads make sure you use anti seize on whichever bolts you use. I use ARP studs with nuts, I think it makes installation easier.
i doubt youd be able to find alum. bolts. go with the studs. or if you go with the stainless steal do make sure you use antiseize as mentioned earlyer.
