Varishock coilover conversion results . . .
Discussion in 'Technical' started by mashori, Dec 4, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So I installed these varishock coilover conversion a few month ago. This is what I noticed today.
    They function well otherwise. But this is pretty concerning.
  2. MikeG747
    MikeG747 Member
    Arkansas
    :yikes: Have you been popping wheelies and coming down hard or hitting pot holes? :huh:
  3. Green70
    Green70 Member
    Mason, MI
    1970 Ford Maverick
    I would unbolt the strut and check to see if the lower mount is actually broken or bent. Aluminum does not tend to bend, it will typically fracture instead. :cry: Does the manufaturer of the part provide any type of guarantee?
  4. Dave B
    Isn't the lower support two pieces, that screw into each other? I just did a quick search on Google and found nothing similar.
  5. rthomas771
    Their online catalog is broke too !!
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  7. Dave B
    Doesn't call for any Loctite? I wonder if it could be a spring rate issue? Either way, they should be able to handle the load, but that's a lot of weight on those threaded inserts.
  8. yellow75
    Tillamook Oregon
    Looks like it probably can be repaired with some replacement parts if available.
    I think I would look for a different option, imagine what could have happened at Silver State with that breaking all the way :cry:
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I think I'd get some made out of steel. I wouldn't trust aluminum in a single shear mount like that. Or go back with the aluminum and fab a steel bracket for the top side so the cross bar would be in double shear to support both sides....
  10. tody
    tody Member
    cologne, germany
    wow, that's what i would call a bad luck streak!
    hope you'll get that one fixed...
    having some issues with my stroker engine myself i can feel four you :cry:
  11. darren
    Thats scary man. Better get that improved.
  12. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Have you called Chris Alstons yet? Thats terrible. I wonder what they'll say. Looking at that last photo in the instructions, I suspect the threads prob stripped out from that end. There's not much thread in there.
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    alright, so it's time to address these shocks...
    got a few emails back and forth with a tech from Varishock....
    basically he thinks it's improper installation and mentioned that for years these shocks have worked great the way they were meant to be installed .... so he sent me a replacement part and they changed their instructions...
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    they didn't used to offer these other types but apparently now they do... kinda wish I had gotten one of those instead.
  15. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Mo, I'm curious as to how they could have been installed any different than what the "new" instructions show? Whatever, it looks like a lot of stress on those long "wing style" ears. Like the entire weight of the front end plus whatever forces go through the suspension on compression... Maybe if they were steel instead of aluminum?
