versaills diskbrakes
Discussion in 'Technical' started by david nichols, Feb 19, 2008.
  1. david nichols
    david nichols New Member
    i am planing to use front and rear disk off the versaills.the front spindles are in my car 70 mavrick 302. what i need to know is what are the parts that i need to use off the versaills? as for as the brakes the rearend will go in later.
  2. baddad457
    You'll need bushings for the ball joints. There's a guy called "Mustang Steve" that makes these. The Versailles spindles used a larger diameter ball joint stud and the holes for these are larger than the other O.E. disc spindles. Do a search on the guy's name and you'll find his website. Or maybe Ratio411 knows it right off.
