Vin number
Discussion in 'Technical' started by Sore Loser, Jun 6, 2008.
  1. Sore Loser
    Sore Loser Member
    Lisbon
    Maverick
    can anyone tell me where the vin number is located? ive search the entire car and i can not find it. i only have the vin number on the dash board.
    I can not drive the car because of this...
    if some one could show me a pic of the place, i would be apperciated :yup:
  2. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    That's it Left dash almost at windshield, should be all you need. But it also was on a sticker Drivers side door opening at the quarter panel.
  3. Sore Loser
    Sore Loser Member
    Lisbon
    Maverick
    yeah i know... but here in portugal the car inspectors saiy that i need a plate number or a number craved on the chassi... like the new cars have...
    about the plate, ford doesnt supply it anymore, so i though that might be a place in the chassi where the vin number is located
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Check the top of the left fender apron. The number may be partially hidden by the fender.
  5. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Yeah I was going to say that. On my car it is totally hidden by fender. You have to take the left fender off.
  6. Sore Loser
    Sore Loser Member
    Lisbon
    Maverick
    well ive found a small plate on the right side of the where the battery is... i cant see the numbers very well... i hope thats the plate vin number
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The battery is on the right side of the car ... the VIN is on the LEFT side ...
  8. maverick1970
    Missouri
    Wonder if he has found a Buck Tag.
    What is the VIN number of the car?
  9. Sore Loser
    Sore Loser Member
    Lisbon
    Maverick
    the vin number is 2x91f231158
    on the left side i cant see nothing, the was painted long ago so...
    its a small plane with numbers and has the number 231158
  10. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Well, that should do it anyway. The Numbers match. Again on my car to see the numbers stamped on the left side you have to remove the fender.
  11. rthomas771
    Here is a pic of a 72 Comet right apron. You can almost make out the VIN on top lip. The best I can remember the VIN is on both sides. I have a pic of a Stallion right apron showing the VIN also
  12. maverick1970
    Missouri
    Looks like you have what you need then
    2 = 1972
    x = St. Thomas Assembly Plant
    91 = 2 door standard sedan
    F = 302 v8
    231158 is the consecutive unit number
    Does the car have the data tag on the drivers side B pillar? If so post the information from the tag.
  13. Sore Loser
    Sore Loser Member
    Lisbon
    Maverick
    damm that was helpful!!! never knew what the vin number meant.
    yes it has a sticker on the drivers side, and i think it has one in the passanger side too. tire specs and color trims... i left the car at the garage, but ,monday iam gonna post the pics of the stickers and the plate.
    i hope the guys from inspection realy undestand this... they wanted a document from Ford saying that the plates do the work... looks like i have to remove the fender to show them hahaha
    btw thanks for the pic!
  14. maverick1970
    Missouri
    In your other post you indicated the car is a Sprint. If it is truly a Sprint it will have an RB in the trim code on the drivers side B pillar tag. If it is a Sprint, make sure you send all the information from the tags and VIN to Mavaholic here on the forum he is the keeper of the Sprint registry.
  15. Sore Loser
    Sore Loser Member
    Lisbon
    Maverick
    ok then i ll see that. i think thats a sprint because of the interior! but i will take the pics to show!
    Thks!:D
