want to convert over to T5 trans, whats needed
Discussion in 'Transmissions' started by 73cometter, Sep 14, 2020.
  1. 73cometter
    73cometter Member
    Maryland
    73 Comet GT
    Have a 73 Comet, it has a 302 with 3 speed manual trans, I want to convert the 3 speed manual trans on the floor to a T5 trans, whats all needed to do this , whats the parts list
  2. Shorty
    Shorty Member
    Lafayette, In
    Here's what I used to replace the Top Loader 4-speed in my Maverick in May of 2017. This transmission is the same length as my old transmission. I also had to purchase a new clutch disc and new yoke for the front of the driveshaft AND modify the transmission mount. It works to tame my 4.11:1 rear gear and 25" diameter tires. (You could also buy a transmission mount from 71Gold on the forum. I've not had any experience with his mount but heard that it works.)
    Bruce
  3. mojo
    Thanks for posting the links for the Tremec units; though I don't envision going to manual trans, I enjoyed consuming their information.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Shorty, BBMS18 and Maverocket like this.
  5. Shorty
    Shorty Member
    Lafayette, In
    Thanks, Rick, I totally spaced that the OP said T-5.
    Bruce
    RMiller likes this.
  6. RMiller
    Kennewick, WA
    Easy to do, I was about to go over the size issues and the butchery I had to do to the tunnel to fit mine (TKO). Had to remind myself the T5 is smaller and people are fitting them without hacking sheet metal!
    Shorty likes this.
  7. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  8. Powerband
    Powerband Member
    NY's \H/
    Mechanically , the T5 swap isn't too complicated from a 3 speed 3.3.03. A T5 bell and cable or Toploader to T5 Adapter plate and pushrod mod' is simple enough. The 3.03 is not as tall as T5's and other Tremecs, and will probably need some tunnel mod to retain DS angle.
    have fun
    [​IMG].[​IMG] [​IMG] . [​IMG] . [​IMG]
  9. rthomas771
