wanting to upgrade to a 4 lead setup
Discussion in 'General Maverick/Comet' started by x72COMETx, Dec 13, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    im looking at upgrading my rear leafs to the 4 leaf setup but was wondering how tall they sit, right now I have 14x8 cragars with 235/60s on the rear, so what I'm looking for is maybe pics of your guys cars with the 4 leaf setup
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Kyle,
    Pictures, tire size and link to springs in the Showcase.
    Micah
  3. Craig Selvey
    I have the EXACT same size wheels, tires, and 4 leaf springs.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    Cool then that will give me an exact look at what mine will look like thank you
  5. Craig Selvey
    This car also has new front springs with one coil cut off.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Here is how mine sits now with shackles on the back and stock 6 cylinder springs with half coil cut on front
  7. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Members: When you "add" a 4th leaf spring, where are you adding it to the stack?
    Between bottom and middle, or middle and top? (Of a 3 leaf spring set-up)
    Thanks.
  8. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I ordered my 4 leaf, leaf springs new. Sat way too high due to them being new. I added a 1 1/2 inch block to the rear but I still think it sits high.
  9. 7D2 Grabber
    7D2 Grabber Member
    235-60-15 15x7 wheel to give you an idea.
  10. 71gold
    my 4 leaf not only set too high but made for a stiff ride. my Mav was too light in the rear to flex the springs, had to remove bottom leaf.
    as Craig pointed out, the hight of the front springs also changes the rear.
  11. mojo
    I had/have the same "General" springs as Frank. Mine were the same situation, to high, and rode much to stiff for my taste. I rode abt 2 1/2yrs w/ them most unsatisfied w/ ride quality. Frank suggested I remove the bottom spring as he had, I followed his suggestion or otherwise those spring wud have been sold. My main complaint was the bone jarring ride, not so much concerned abt height, although it made about inch difference -- can't recall exactly how much. Removing the leaf made a significant in ride quality.
    Only regret - wish I had removed the 4th. leaf a lot sooner.
    Ur car sitting pretty low in front -- speed bumps/humps not a problem in ur area?
    Crazy Larry likes this.
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
    I'm thinking of buying from laurel mountain mustang
  13. 7D2 Grabber
    7D2 Grabber Member
    I'm assuming your talking about mine up front. It's just a tiny bit too low. I have coilovers up front so I think I'm going to raise it a 1/2 inch. I'll remove a leaf on mine.
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I had 4-leaf from J.C. Whitney (which are no longer available). The car sat at the stock height but rode much too stiff.
    I should have removed the bottom leaf, but instead I bought a new set of 3-leaf from ESPO. The ride is better but the rear of the car sat too high. I loved that in my younger days, but not now. I installed 1-1/2" lowering blocks to bring it down to where I like.
  15. Craig Selvey
    My 4 leafs came from ESPO. Great ride quality.
    The car below had 4-leafs installed by previous owner. NO air shocks....this was just the 4-leaf springs. Rode like a buck wagon (terribly harsh ride).
