water flow?
Discussion in 'Technical' started by 71gold, May 2, 2007.
  1. 71gold
    i pre-zoom that the water comes from the w/pump to the heater and then to the intake.:yup:
    i am installing my ...heater control valve... and it is directional (with arrow). :D
    ...:bouncy: ...
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Just pull the hose off the water pump and see if water comes spraying out when you start the motor. :D (Aside from the water that runs out when you take the hose off :rofl2: ) It sounds right given that the top hose is the outlet, but I don't know for sure.
  3. don graham
    sorry, i've never checked to see if any of my mavericks have a heater.:rofl2:
  4. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Ya, whats this heater thing ya'll keep talking about :D .
  5. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    You guys are COLD!,,,,It's that thing so when you put your taco's on the floor it keeps them warm!
  6. 71gold
    well let me ask this question...will the last four (4) people that posted please..."bite me"!!! ...thank you very much. :p
    ...friendless Frank...:cry:
  7. Thack
    Thack vision advicator
    Moreno Valley Ca
    No, it goes from the manifold to the water pump. The water in the manifold is under pressure and the bypass, heater and radiator inlet on the pump are under vacuum so to speak. The pump forces the water into the block and up to the manifold.
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    mine goes from the intake to..............the intake :rofl2:
  9. 69 ina 1/2
    Okay Frank, I'll be serious and answer your question...
    I could be wrong on this but here goes...
    In the southern hemisphere water flows counterclockwise.
    In the northern hemisphere water flows clockwise.
    yup, I just went to the restroom, definately counterclockwise :rofl2: .
    FFJ :Handshake (y)
  10. don graham
    matt, frank dosen't want to pull the hose off as he might get the garage floor dirty.:sweep:
  11. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Maybe we should ask Don Imus ? He seems to know alot about Hose. :yup: :p Sorry guys...had to do it.
  12. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Brrmp-CLANG!
    :clap:
  13. scrapper60
    scrapper60 MCCI Member
    Alabama
    Frank asked questions about AC in the winter,,,,,,,, now about heater water flow in the spring, (85*) here today. Go figure.
    Effie's friend
    Jerry
  14. mavman
    mavman Member
    Arkansas
    Water flows in this direction. From radiator to water pump, then the pump moves it through the block and up through the heads, then out into the intake (302 and 351w...351c doesn't have water in the intake) and back into the radiator. If you have a heater, one hose goes to the intake and one hose goes to the water pump. See...simple? Think about it...a heater core doesn't care which way water goes through it. Just put one hose on the pump and the other on the intake. The hot water coming out of the intake will flow through the heater's core and then out of the core and back into the water pump to be recirculated.
  15. Grabber5.0
    Kansas City, MO
    71 Grabber
    There's your answer Frank. :)
    The heater core may not care, but it sounds like the valve that shuts the flow off when the a/c is on appears to care which direction the water is flowing, since it has an arrow on it.
