water on my floorboards?
Discussion in 'General Maverick/Comet' started by Blackdog455, Nov 24, 2012.
  1. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    Whenever it rains my maverick always seems to get drenched with water on both the driver and passenger side floorboards above the carpet. I know it's not coming from a leak in the weatherstripping. How is all this water coming up from under the car into my car?
  2. koldham
    koldham Member
    Walnut Grove, Gerogia
    1973 Maverick
    dude my cars been leaking like a MO-FO for the past 3 years. checked your cowl, window rubbers, door rubbers, and where the antenna enters the car. ive replaced almost all the grommets on the firewall too just to be sure.
  3. G3blues
    G3blues Member
    MI
    1972 maverick sprint 302
    Your cowls are probably rusted out. Pour a gallon of water down your cowl vents in front of your windshield and see if the water comes inside.
  4. mav1970
    If you took your front fenders off you would see 2 drain holes (1 on either side) on your cowl. These get blocked with pine needles and leaves and let the water lay in your cowls instead of draining out rotting out the cowl assembly letting the water run into the interior of the car. Ford in it's infinite wisdom decided that no primer or paint was needed for any type of coating to protect it from rotting out :hmmm:
  5. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    Thanks, I will go take a look at the cowls.
  6. Tannersg1
    Tannersg1 Member
    Classified
    I have the perfect solution, don't drive it in the rain or wash it! Works for me! Lol...
  7. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    I live in Western Washington, no car cover because it gets to windy here and the car cover would be ruined in a month (gone through two already). No room in my parents garage, so it has to sit outside. It's inevitable, it will get wet 12 months 320 days of the year! haha.
  8. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    But, my wife and I just bought a house with a shop on the property, needless to say, you can guess what is going to be parked in that shop space!
  9. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    I completly removed my cowl cover and it still leaks like a mo fo....just sayin'...
  10. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Yep I just picked up a magnetic cowl cover off ebay. Hoping to be disciplined about using it. Then I have to figure out how I'm gonna get it fixed since the Comet is my daily driver again.
  11. 71gold
    water also enters the weep holes at the base of the windshield...around the wiper stems and the holes where the hood to cowl seal mounts...:yup:
