Water pump And pulley
Discussion in 'Technical' started by demo913, Jun 30, 2011.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Now that I have removed my power steering pump for my manual cconversion how do I route my water pump belt? Is there a certain setup I need to get to attach to my water pump that has a bracket and pulley?
    Thanks...
  2. rthomas771
    If I'm reading you correct...you will just need to buy a shorter belt for your engine that doesn't have power steering
  3. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Where does the belt go to? All i have is a water pump with nothing to run the belt to.
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I dont see how I could get a belt around the crank pulley and the water pump pulley.
  5. Green70
    Green70 Member
    Mason, MI
    1970 Ford Maverick
    I have a single belt set up that goes around the crank, water pump, and alternator. The alternator has an adjustment bracket to tighten the belt.
  6. baddad457
    Ditto, you now need to change pulleys and route the belt around the alt, w/p and crank.
  7. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    So to route it with the alt and crank I assume I need a water pump pulley that has a double belt option.?.
  8. baddad457
    Yep, or a single sheeve pulley that lines up with the alternator pulley. I've got about three extras like this that I think are what you need, but if you're interested in em, I'll need to check the backspacing with what you need. These pulleys came off 351W and 351C/M/400's.
  9. Green70
    Green70 Member
    Mason, MI
    1970 Ford Maverick
    I just replaced my pulleys with chrome ones and I have the old painted single groove water pump and single groove crank pulley left over. The crank pulley is the 3 bolt version so if that is what you have, they should work for you. Let me know if you are interested.
  10. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Mine is a 4 bolt for a 75 351w. I have the single groove right now and it isnt even close to lining up with the alt and crank.
  11. baddad457
    If you have a 351W crank pulley, then you need a W/P pulley from the same application. I have three extras like this.
  12. rthomas771
    It seems like Ford made 100’s pulleys for the same engine. I found out the odds are against you trying to find a pulley to match your pulley. It’s easier finding a matching set by getting the pulleys off the same engine. Or do what I did and machine a spacer to shim one of the pulleys.
  13. baddad457
    This is generally true for 302's, but all 70's 351W, C , M and 400's used the same crank and waterpump pulleys, as far as their spacing goes. There were some variations in pulley diameters among these.
