Water temp dummy light vs temp gauge
Discussion in 'Technical' started by gdemopesq, Jan 13, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I am putting in an oil pressure and water temp gauge. Sunpro. I want to keep the dummy lights in. I made a small manifold for the oil sensor dummy light and Sunpro pressure sensor to use the same hole in the motor. This will work fine.
    I want to do the same kind of thing for my temp dummy light and sunpro temp sensor to also work. Any thoughts. Reason I want both. As I am driving casually I will likely see a light before the gauge. Does the motor or any any part have a hold for a temperature probe?
  2. Craig Selvey
    Should be several places on the intake or the water neck where you can put the two sensors in.....the aftermarket one and the factory one. I did it on mine.
