weather strip sealer
Discussion in 'Technical' started by Racer_X, Nov 3, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    do i need to put any sealer along the bottom edge of the back window sill before i put the gasket and widow in?
  2. Mavman72
    Yes you must use a sealer in that location, or it will leak right onto the package tray and into the trunk.
  3. Racer_X
    North Carolina
    i have a roll of that beutyl stuff can i use that? it looks like a big roll of black playdough
  4. Mavman72
    I would use urethane sealer...Most of the butyl tape stuff is not soft enough to conform and seal properly in window sealing apps...
  5. Racer_X
    North Carolina
    what im using you can conform it to the window sill and its really thick, not like tape at all
  6. Mavman72
    Yes, its more like a thick string/rope but...I wouldnt take the chance...If it doesnt seal. You will have to take it and the glass out to re-seal it.
  7. Racer_X
    North Carolina
    what forms does it come in?
  8. Mavman72
    Comes in a caulk tube.
  9. Mavman72
    [​IMG]Product looks like this...3M bedding and glazeing compound. This is what you want to use on windshield and back glass when installing it...
  10. Racer_X
    North Carolina
    ok thanx for the info
  11. mojo
    I am confused on the subject of windshield sealants. Some say use butyl on the older cars and some say use urethane. Most say "flow grade butyl.
    http://www.technologylk.com/crl-windshield-sealant-lk-CRL7711.html
  12. 71gold
    this is what they used the other day to seal my windshield...:yup:
  13. Racer_X
    North Carolina
    could i use both the butyl rope and the sealer, rope between meatl lip and rubber gasket and then seal between the gasket and the body?
  14. Dave B
    The issue with Urethane on older cars, is the car body will flex, and the gasket will flex along with it, if you lock it all in tight, it has no where to go, sometimes breaking the glass.
  15. Racer_X
    North Carolina
    thats what i have herd too
