Im about to put in the "DOOR GLASS RUN" weatherstripping on my 2 door. The glass and regulators are OUT right now. Should i leave the windows out or put them in before i put in the weatherstripping?? thanks chaz.
You can leave the glass out.Put the regulator assy in though first so you dont risk damageing the new window fuzzies.
how hard are these to put in? I'm having trouble just getting the old ones out and am trying to decide if I should wait until after paint to install (this is what I want to do) but would hate to scrape fresh paint trying to install them.
Dont put the new ones in till after paint!!Gotta get some paint in there so it looks good.If you go slow you wont scratch anything.The old ones will pry out with a sharp thin screw driver or putty knife.Just go slow.
oops, I meant belt line I read door glass run and thought Beltline. Install beltline before or after paint? Sorry for the highjack. Just to keep it on topic, do the door glass run weatherstripping come with the antirattle clips?
Good ones come with the clips.Belt line weather stripping after paint .Do paint first!then put new stuff on car.
Mavman, You said the good door glass run weatherstripping comes with antirattle clips. I bought from AK and no antirattle clips. where do you suggest I get them?
"antirattle clip" where is this located? i have a...Glass guide...at the top outside edge of the door. i just picked my door up from the paint shop about 30 mins. ago. there is nothing on the door but its skin... i will install all new weatherstriping, handles, glass run and beltline... Pics. later... ...Frank...
I think that's it, It's a vinyl coated metal clip attached to the window run at the top of the window frame. I think they were riveted to the rubber glass run.
I was in error when I read your post.Yes that clip is a glass guide,as for anti-rattle clips? mavs were cheap cars, didnt have them to the best of my knowledge.My T-top fireburp formula has anti rattle blocks on the beltline weather stripping(the glass rattles anyway LOL)if your glass rattles when rolled down,try adjusting the glass stop at the bottom of the door to keep the glass between the beltline stripping instead of below it.good luck.
ok, regardless as to what you call it. They don't come on the new glass run weatherstrips I have. do they come on any?
Thats odd??? I have a set from Autokrafters and they have the guide on them.Let me go look at who manufactured them...
