Wednesday TNT at Pacific Raceways.
Discussion in 'Drag Racing' started by courier11sec, Jul 5, 2004.
  1. courier11sec
    courier11sec Member
    Tucson, AZ
    Hey Pacific Northwest folk.
    I'm heading to PIR for test and tune on Wednesday weather permitting.
    Gates open at 5pm and we ran untill about 10:30 last time.
    Coop I know you're in. Anyone else?
  2. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    Rats and Double Rats...I really wish I could go...:cry:
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    Cliff, if I ever get around to bringing my car home I'll be calling you all the time to drag you to Mission!
  4. Mercurycruizers
    Venetia, PA
    I'd consider being dragged to Mission with you both.
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    Went down. Track was not great. couldn't hook up to save my life. Ran a best of 12.43@112.28 with a best 60' of 1.99 (different runs)
    Scored a pair of 28x10.5 slicks brand new for $50.00
    A pair of rims and tubes from now I should be able to get asked to leave the track.
    Coop. you would have dusted about 80% of the field.
  6. Mercurycruizers
    Venetia, PA
    Bummer......I spaced it out. I didn't remember until I got home tonight. Let me know the next time you go Ray.
  7. Old Guy
    Old Guy Member
    Was curious as to what kind of slicks you stole ur I mean bought for cheap. We get 50 a piece around here for used MT's. Also, is there some reason for running tubes in them, have heard that unless you use the regular racing tubes, they will not wrinkle as well. Never have used tubes and was just wondering how they work out.:confused:
  8. courier11sec
    courier11sec Member
    Tucson, AZ
    Goodyear eagles.
    I was under the impression they would have a hard time holding any air without tubes in them.
    If I can get away without tubes I will though.
    I feel like I got a smokin deal on these things, but I'm worried they won't fit.
  9. mavman
    mavman Member
    Arkansas
    Here's a trick I learned the other day. Yes...GY's are notorious for leaking air through their paper-thin sidewalls, but Dawn dish washing soap applied to the inside of the sidewall, then let dry completely will slow down the leak.
    I found this out the other day while working on a lawn mower tire that leaked air through the sides. I took it off, inspeced the beads, then soaped it down pretty good...and got interrupted. In the mean time, the soap dried and after I had it mouted, the leak was gone. I have read this trick before on another board...but doubted that it'd work. Apparently it does, well, at least on lawn mower tires.
  10. Grabber71
    I ran my car with Goodyears for about 4 years without tubes & screws and had no troubles. Just mark the tire and rim and check it after every run...if the tire slips on the rim it might break the bead which is...well...not good. I have a set of Mickeys now and was told if I screw them to the rim...use tubes. So now I'm screwed(to the rim) but I'm just using reg car tubes... and have had no problems. If you use screws..use the correct ones though...
  11. courier11sec
    courier11sec Member
    Tucson, AZ
    Well sounds like it's worth giving it a shot without tubes. Next time I go I'll have them with me. I hope they fit the car on 10 inch wide rims!
