Weird oil pressure glitch in my hemi 04 Dodge Ram 1500
Discussion in 'Other Automotive Tech & Talk' started by scooper77515, Jan 23, 2015.
  1. scooper77515
    So I have the cruise control on, going 65 for about 15 miles, and all of a sudden BING-BING-BING "CHECK GAUGES" comes up.
    Oil pressure gauge has dropped to ZERO!!!
    I let off the gas and try to immediately find a place to safely pull over and check things out, and the pressure comes back up about 5 seconds later.
    Oil level on dipstick is normal. Color is clean. I am only 1500 miles into the last oil change. And this has not occurred again since, over the past week, and I have put on about 600 miles.
    I am assuming a sensor wire or something shorted out for a second.
    Any other ideas? Should I worry and start saving up for a new engine?
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Disconnect to wire going to the oil pressure sensor I believe its a green connector (haven't worked on many mopars in a few years). They leak oil through the sensor and fill the connector with oil and cause issues like you describe.
  3. scooper77515
    Cool!
    I figured someone on here would know how to fix this!
