Welding repairs and old undercoat
Discussion in 'General Maverick/Comet' started by Powerband, Feb 11, 2020.
  1. Powerband
    Powerband Member
    NY's \H/
    A common situation discussed with my current project includes rear torque box and spring hanger repair.
    Not often discussed is related common problem of heavy old dried tarry undercoat .
    Suggestions appreciated how anyone's dealt with this reasonably for panel/subframe repairs.
    ... Need to clean adjacent steel to weld to new steel . I've used bonding as well as stitch welding for panel repairs and structural subframe/spring works best with good clean weld surfaces.
    thanks
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I have been using a needle scaler, works amazing on the stuff that is set up and hard. It isn't the best on the gooey stuff, just seems to move it around.
  3. 71gold
    I lucked out and it was a cold day when I did mine with a needle scalier and it all came off...:thumbs2:
    BBMS18 likes this.
  4. Craig Selvey
    I have used a gasket scrapper and a hammer.
  5. Acornridgeman
    Wisconsin
    Air scraper and a wire brush cup on the angle grinder followed by lots of rags with solvent. Anyway you do it, it makes a mess of the shop. :)
  6. Tannersg1
    Tannersg1 Member
    Classified
    I borrowed a high end heat gun from work and heated it up and it came right off with a putty knife
  7. yellow75
    Tillamook Oregon
    I was reading that if it is in an area that you can apply dry ice to it from either the top or by laying the ice on it it almost falls off . Seems like there would be far less mess than heating it up . If you were able to use a can of compressed air sprayed on it with can upside down that would freeze it as well
  8. Powerband
    Powerband Member
    NY's \H/
    .. thanks for replies. Never simple solution but likely use a few different methods in different places and needed tips and encouragement.
