wensday night tire trivia question
Discussion in 'New Members Forum' started by jnkgal, Aug 7, 2013.
  1. jnkgal
    jnkgal New Member
    Daisy Land
    If atmospheric pressure is 14.9 psi and the pressure in the tire is 12 psi does that mean the total pressure is 26.9? what is the actual pressure to hold a tire bead on a rim. The pounds per square inch :yippee:
  2. Red1972Grabber
    Northern California
    I have no answer to your question, but welcome to the forum from Northern California!:chirp:
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No. It doesn't mean that at all.
  4. mav1970
    :Welcome: from a fellow 70 owner in Northeast Pennsylvania
  5. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    :Welcome: from Stone Mountain, Ga.
  6. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  7. 71gold
    :bouncy::Welcome:...:Handshake
    say it takes 50 lbs. of air pressure to seat the tire to the rim. then you take and remove the valve stem center. all the tire pressure is removed and the tire is still on the rim. ...so...at rest, 0 lbs. of tire pressure to hold tire on the rim...:huh:
    my thinking...12lbs. is 12lbs... a tire would act as a balloon would, it would expand/contract with a given air pressure as the...atmospheric pressure...changes...:hmmm:
    it's way to early to be thinking about things like this...
  8. simple man
    simple man Member
    Bunnell,Florida
    Welcome!
    In answer to your two questions, The air pressure inside and outside the tire are the same ( 14.9 psi ) before you start to inflate the tire so you won't add the pressures together. Now, if you have 35 psi in your tire and drive up a mountain that is 10,000 ft, the atmospheric pressure will now be 10.1 psi so you will add pressure to your tire at altitude!
    To keep a bead seated on a rim ( to drive on ) usually takes about 12 psi. This depends on the diameter and width of the rim and the type of tire you're using. When I used to have dune buggies, I'd run 4 - 5 psi on the beach and inflate to 12 psi to drive on pavement. I had tubes in the tires and screws through the rims so that the tires couldn't slip on the rims. :)
  9. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    The trick to understanding is knowing the difference between PSIA and PSIG.
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  11. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Pressure inside the tire is usually rated as the internal pressure being exerted against the external pressure. So as Simple Man said, as atmospheric pressure drops internal tire pressure increases.
  12. jnkgal
    jnkgal New Member
    Daisy Land
    Thanks
    Thanks for the warm welcome to the site. :thumbs2::)
    now time to get out and work on one of our race cars. :drive:
  13. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the forum from West Virginia.:Welcome:
