What all should I check?
Discussion in 'Technical' started by maxsideburn, Feb 16, 2004.
  1. maxsideburn
    maxsideburn Member
    Lafayette, Louisiana
    1976 Ford Maverick (200CID I6/AUTO)
    Ok I've had this car for about 2 weeks now and I've gotten a chance to do a few things, but not much. I've got a few days off soon and I'm about to really go through this car to see what I've got. What would you all suggest that I check, mostly under the hood? I've already got a list to check, but I want to make sure I don't miss anything.
  2. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    compression
    change tranny filter/fluid including torque converter
    ball joints
    pressure test cooling system
    flush cooling system add new coolant
    all new points/plugs /condensor/cap/rotor/wires
    new air filter and pcv valve
    bleed brakes
    all lights
    carry on boys... what else?
  3. 71gold
    he said a few days. i think you have him booked for them...frank...:bananaman :bananaman
  4. New2Maverick
    New2Maverick The Newbie Sponge
    Oregon
    1974 Maverick 4 dr, v8 302
    When I did all that to my car I still had a day and a half of weekend left over. And it wasn't a long one either.
  5. don graham
    you might want to check the brakes, the shocks, and the rear end fluid. also the universal joint.:)
  6. GPZ1100
    GPZ1100 Professional Lurker
    Tejas
    Kawasaki 700 Prairie, Gpz1100, & Concours C14
    muffler bearings. don't forget the muffler bearings! ;) look for pinched wires or scorched places near wires.
  7. New2Maverick
    Oregon
    if he checks the muffler bearings then he needs to make sure that the bottom of his turn signal resivior hasn't become brittle, as turnsignal fluid is highly crosive and has been known to eat right through the plastic bottles over the course of many years.
    :bananaman :clap: :bananaman :clap: :clap:
  8. maxsideburn
    maxsideburn Member
  9. scott
    scott Member
    new jersey
    yeah that WOULD suck...stuff will rot the floorboards too!
  10. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    how do you check the rear end fluid?
  11. scott
    scott Member
    new jersey
    enema
  12. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    drive shaft has to be removed?
  13. don graham
    usually there's a plug in the rear housing. easiest way is to remove it and stick your finger in or just fill it until it reaches the whole. i use synthetic oil in mine. :) p.s. i'm not sure if all the 8" have them. my 8" ones and my 9" both have them.:)
  14. maxsideburn
    maxsideburn Member
    why the hell are we still talking about turn signal fluid? hahaha
    I think this joke has run it's coarse, lol
  15. New2Maverick
    Oregon
    I think they have switched from turnsignal fluid to the gear oil in the rear end housing.
