What can I do to raise the rear
Discussion in 'Technical' started by Hairy W Bush, Oct 5, 2014.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    I am putting 17s on the car and the gap between the tire an the panel is 1 inch. It looks great but I am concerned about suspension travel. I was thinking shackles but the leaf springs are already low on the long stock shackles.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    One inch is plenty.
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    ok i hope so
  4. Mavman72
    Or get new springs...
    Crazy Larry likes this.
  5. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    one inch should be enough for the rear. if not then shackles is your easiest way to lift it
  6. Craig Selvey
    Longer shackles are not a suitable way to fix ANY suspension problem with a Maverick. All they do is make the situation worse.
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    well if I have any trouble I'll be sure to try the new leaf springs. over $200 for the pair though...wow
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The proper way to do it, is to get wheels with the optimum back-spacing and tires that are not too wide to fit under the body.
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    they would fit fine if I didn't have to use adapters.
