What cfm 4bbl carb ???
Discussion in 'General Maverick/Comet' started by 302-72-mav, Aug 29, 2009.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    what 4bbl cfm carb should i use read my facts below ) and what carb BRAND do you like/hate
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    and i ported the heads
  3. Mavaholic
    I have a Demon 650. Runs great!!
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    i have a holley 600 w/vacum secondarys have not ran it yet but every one i have talked to said that is the perfect carb for my motor.302 roller e-303 ford racing cam,289 peformer intake,e-7 heads ported,mallory unilite dist.
  5. bmcdaniel
    Still the original cam? What rear gears?
  6. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    600 Holley
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    600cfm anything would work good
  8. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    600 cfm holley.
  9. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    670 Holley.
  10. Bryant
    600 cfm. a holley double pumper will give you the best seat of the pants feel. a vac seconday has the potental to get you beter gas milage. a edelbrock is concived to be a easyer carb to work on, but in my experience it just doesnt performe like the holleys can.
  11. scooper77515
    Everyone told me 600 cfm is plenty, but I bought an Edelbrock 600 model 1406 (electric choke) and bought the calibration kit, and every time I did a mod to the motor or exhaust, I had to richen it up a bit. Eventually I ran out of calibration, sold it to someone with a weaker motor, and got a 600 double pump holley with LOTS more room for calibration.
    But, if I bought one new, I would likely go with a 750 Holley DP.
    Tried a demon 650 and it was too rich out of the box, but didn't mess with calibrating it because I was borrowing it while the owner tried out my edelbrock. He liked the edelbrock better on a stock motor, as did I on a slightly modded motor.
    So, I guess the Holley type carbs run a little richer, out of the box, but have a greater range of adjustability.
    So I recommend a holley, 600-750 cfm range. More like the 600 for your setup.
  12. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    holley 600
  13. 302-72-mav
    302-72-mav Member
    sactown CA
    yah it's a stock internal motor and a stock rear end
  14. scooper77515
    600 will be plenty for you and give you plenty of room to grow, especially if you go with a Holley.
    Edelbrock will be simpler at first, but you may outgrow it, and it seems most guys just end up with a Holley in the end, and then you have to relearn the entire carb.
    So I suggest you start with holley.
  15. JHodges
    JHodges thumper
    Dora Alabama
    600 vc holley will be plenty. I have the model 80457 on mine and like it
