what clutch and flywheel??
Discussion in 'Transmissions' started by Joe Dirt, Aug 12, 2010.
  1. Joe Dirt
    do i need for my later 5.0 to jive with this 3+1 trans
    can i use a fox mustang 10.5" setup since the clutch splines are the same???
  2. Earl Branham
    Lugoff, SC
    Russ; you will need a 50oz imbalance 157 tooth flywheel and 50oz balancer. that's what I am using on mine.
  3. Joe Dirt
    yeah just wondering if the 157 tooth late model mustang stuff (disc and pressure plate)will work with the trans as i found a decent deal in a light weight setup
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    i got a 12 pound aluminium flywheel and stage 3 clutch and hp pressure plate and the throw out bearing and pilot shaft bushing plus the flywheel has a removable counterweigh blancers so i can have it 28 ounce counter balance then 2 seconds later 50 ounce
    i got the kit off of ebay from f1performance (i think thats right) but any way it's all made by (((center force))) it was like $480
  5. Joe Dirt
    is this kit for a fox mustang? trying to get my info straight here
  6. 302-72-mav
    302-72-mav Member
    sactown CA
  7. rayzorsharp
    I'm running the same flywheel with Centerforce clutch and pp also. Works fantastic!
  8. Joe Dirt
    thanks guys that took alot of thoughts off my mind and should help me greatly
