what do i do next?
Discussion in 'Technical' started by fan2488, Oct 20, 2006.
  1. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    my car starts great but when it gets to operating temp. i shut it off and will not turn over. once it cools down, then it starts right up. i have new battery cables, fully charged battery,new alt,new starter relay,new voltage regulator,new mini starter,new timing chain and gear, the timing is set at 12*btdc, it is a stock 302. i added headers and a 4bbl. im stumped, any ideas?
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Sounds like heat soak at the starter or high resistance in cables. What size battery cables? Did you try mor than one starter?
  3. CornedBeef4.6L
    no longer here
    Have you tapped on the starter while trying to turnb over to see if it does any better?
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Ed, I too use the mini-starter. I bought it at Vato Zone (application: '92 Mustang 5.0).
    When I was having trouble with the starter/flexplate engagement, I took the starter back for an exchange. I told what was going on and they gave me a replacement without hesitating.
    The starter is one of the easier items we can R&R on 302's. I'd try talking to the Parts Counter guy (where you bought the starter) into exchanging starters - for starters. (I just made a funny!).
    Good luck and keep us posted.
  5. PaulS
    Does your Ground cable go to the engine or frame? You have to be sure the engine has a good ground - At least #2 wire. The cables to the starter and solenoid should be#2 as well. #4 or #6 iscommon but they have more resistance than you should have, especially with the reduction starter.
  6. fan2488
    fan2488 Member
    spring,TX
    MAVOWARSounds like heat soak at the starter or high resistance in cables. What size battery cables? Did you try mor than one starter?
    this is the second starter the first one was a stock one.
    Rick BookEd, I too use the mini-starter. I bought it at Vato Zone (application: '92 Mustang 5.0).
    i dont think there is any engagement problem.there is no funny sounds when it starts.you did make a funny:clap:
    PaulSDoes your Ground cable go to the engine or frame? You have to be sure the engine has a good ground - At least #2 wire. The cables to the starter and solenoid should be#2 as well. #4 or #6 iscommon but they have more resistance than you should have, especially with the reduction starter
    ground cable goes to the engine.i think they are #2 but could be #4 i will check in the morning.cables are new.
  7. Rick Book
    Rick Book Member
    Thailand
    Sorry. I didn't mean to imply your starter wasn't engaging - just that it might be getting weak. Replacing it (for freebie) would eliminate that variable.
  8. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i would say starter , my dads truck was just doin the same thing, it would fire up on the coldest of days then , driving it for a while then it would warm up and it would not start , sounds just like what your problem is , but just my .02 but
  9. fan2488
    fan2488 Member
    spring,TX
    i had my stock starter checked at auto zone.they ran it through 5 cycles checked fine every time. remounted it still did the same thing. funny thing is it didnt do this untill i added headers. i figured i would get a new starter anyway.got a mini starter(e-bay) still does the same thing. do i have to have a ground from the engine to the body or frame?
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If headers brought about your problem, then it is heat soak to some degree.
    Did you make sure you had 2ga or better cable?
    Is your battery in the trunk?
    Do you have some header wrap laying around that you could shield the starter with?
    Does retarding your timing a bit help? (I know you have it right at the moment, but I was wondering)
    Dave
  11. Mavaholic
    If they check it like most places, there is no load put on it and certainly no heat involved. Its not really a valid check under those conditions. I'd agree with grounding and cable size issues.
  12. CornedBeef4.6L
    no longer here
    Yes you should have at least the neagtive cable and another ground wire of similiar size from motor to body.
  13. fan2488
    fan2488 Member
    spring,TX
    fixed
    after all of this work.it turned out to just be the battery.saturday morning i warmed the car up,then turned it off. would not start.hooked up the battery charger for about 10 min. started right up. turned it off again,again it did not start. my neighbor brought over a new battery,fired right up. so i bought a new battery saturday morning been working fine since. this morning i drove it around the neighborhood shut it off started right up. never thought about the battery before because it always started the first time. boy do i feel like a dope.:slap:
  14. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Rick, I have been looking to get a mini-starter for my 250 Maverick to help with header to starter clearances, and I'm pretty sure that the 250 and the 302 take the same stock replacement starter. That would mean that the mini-starter you are using should fit my application with a C-4 tranny. Did you really mean Auto Zone? Do you happen to have the part number handy? Thanks. :bouncy:
  15. Rick Book
    Rick Book Member
    Thailand
    DURALAST DL3205S LLT $40.00 core charge $98.49 [​IMG] Premium quality reman, some new components
    [​IMG] VALUCRAFT
    With solenoid
    3205S 1 YR $40.00 core charge $73.4 Remanufactured unit. permanent magnet planetary gear reduction
    GOLD-DURALAST
    New
    DLG581S LLT $40.00 core charge $119.99 Designed for maximum durability 100 % new direct replacement starter for post or spade solenoid
    see autozone.com and click on "shopping" look for a 1992 Mustang 5.0
    or just go into AutoZone and tell tell them you want a starter for a 1992 Mustang 5.0 , "Automatic" if they ask. The 5-speed and auto should be the same.
    You can probably bring in any old starter as a core. Good luck.
    Hey Ed. More than likely, your battery needs replacing. ;)
    (Glad you got it fixed! :thumbs2: )
