what do you guys think?
Discussion in 'Technical' started by cenc1984, Oct 5, 2007.
  1. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    1972 Maverick Grabber
    I have a manual steering box that just went out on me and here are my options.
    1. I go out and get a new or refab. manual steering box. OR
    2. I have a power box that will bolt right in.
    now here is were you all come in. What does a car with a power steering box handel like? (the ram and pump will not be put on the car just the box) will this work?
    thanks,
    Alex O.
  2. Mavman72
    Yes,you will experience the need for extra effort when turning at low speeds(paralell parking) that sort of thing.Otherwise it should be fine.I understand the power box is supposed to have a qucker ratio too.
  3. Jamie Miles
    Alto, GA
    I've had a few
    The quicker ratio is the cause of the increased steering effort, which in my opinion, really isn't that noticeable. I've driven much worse.
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I love my 71 with power steering. It's so smooth, I can't tell ya. The other 71 I have is manual but I have to use 2 arms to turn it at all times unless I'm cruising freeway.
  5. baddad457
    I'd try the power box before buying a new or rebuilt one. I converted my 77 Comet to manual and reused the power box and it's nothing to turn it.
  6. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    from what you guys say I think I'll put in the power box.
    Thanks,
    Alex.
  7. scooper77515
  8. 71gold
    ...a lot also depends on the size steering wheel you have...(y)...
    ...:party3:...
  9. baddad457
    :drive:Yea, but didn't those tiny assed 6" wheels go out with the 70's ? :biglaugh::rofl2:
  10. Mavaholic
    I always run ps box on a manual car. The steering wheel size definitely makes a difference.
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    how complicated would it be to add a power box to make my 71 a little easier to turn?
  12. baddad457
    Just the box, or the full system ? The box by itself makes it harder a bit to turn with no power assist. To make it power, you have to have the pump, lines, power ram, different drag link,the pitman arm & the ram mount bracket on the frame. If you want a powerram and draglink, pay the shipping and I'll send that stuff to you.
  13. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    I have a stock steering wheel. was the test done with a stock one or not?
  14. scooper77515
    The test was done with NO steering wheel. It was a torque wrench on just the nut in the center of the horn button area. So, regardless of the size of the steering wheel, those numbers will still stand.
    Still, a bigger steering wheel will level out the way it feels on the hands.
