What do you use to cut sheet metal?
Discussion in 'Tool & Shop Talk' started by rustymav1974, May 7, 2011.
  1. rustymav1974
    rustymav1974 Livin' The Dream
    Media Gallery:
    Albums:
    Midland, Texas
    1974 Maverick
    I need a tool to cut off my rusted quarters and I have some small spots (look like bullet holes honestly) on the doors that need to be cut out too. I have no idea what I should use. I've heard of using a cutting torch but I don't cut metal often enough to justify buying one. Is there something I can buy to use with a common power tool most people would have?
  2. injectedmav
    injectedmav Well-Known Member Supporting Member
    Media Gallery:
    Albums:
    Georgia
    1972 Maverick 2dr 5.0l EFI, 2003 Expedition(wife's), 1991 Toyota p/u
    Thinnest cutting wheels(abrasive) you can find for a 4.5" grinder or airtool. If you can spot sand blast the area, you can see where the rust actually has punched through or thinned the metal that you can miss just by looking.
  3. modrisco
    modrisco Member
    Canada
    Avaiton hand snips work well for cutting a single layer of sheet metal. For your door holes start in the hole and cut out a circle around it. They will also work well to cut the repair piece. Pick up a left and right set.
    Mitch
  4. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I just use an electric die grinder with a thin cutoff wheel. Way easier than cutting with an angle grinder, because the wheel is perpendicular to the tool, so you can see your cuts. Like this, but with a cutoff wheel instead of a grinding wheel.
  5. maverick75
    Media Gallery:
    38
    Albums:
  6. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    69.5 Maverick - (2)72 Maverick- 64 comet cyclone- 69 mustang 70 cougar -69 Ranchero - 69 Cobra-
    Harbor freight air saw here to for close work where you have plenty of room behind the area your cutting. For harder areas, I use a diegrinder with a cutoff wheel.
  7. PaulS
    Air saw. cut-off wheel, nibbler or plasma cutter - never a torch if you want a straight panel when you are done.
  8. Dave B
    Media Gallery:
    34
    Albums:
    I pretty much have one of everything, but this is one tool I love.
  9. darren
    darren Well-Known Member Supporting Member
    Media Gallery:
    12
    Albums:
    My good friend Tim, our body man at work. LOL.
  10. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I've got the electric version, I was pretty impressed with it as well. Used it to cut the hole in my hood. I hate doing circles with a die grinder
  11. rustymav1974
    Media Gallery:
    Albums:
    Midland, Texas
    1974 Maverick
  12. injectedmav
    Media Gallery:
    Albums:
    Georgia
    I have one like that and it does the same thing. I decided to just get a new one.
  13. rustymav1974
    Media Gallery:
    Albums:
    Midland, Texas
    1974 Maverick
    By new one do you mean that you bought the same one? or another brand? :16suspect
  14. mavgrab302
    mavgrab302 MCCI Florida State Rep Supporting Member
    Media Gallery:
  15. Dave B
    Media Gallery:
    34
    Albums:
    Don't forget to oil your tools!! A little oil goes a long way, if you don't they'll rust up inside.
  16. injectedmav
    Media Gallery:
    Albums:
    Georgia
    I bought a different brand. The compressor I am using is more than sufficient. I have used some that are airhogs, but this one I borrowed and it didn't even want to spin, so I oiled it and nothing, spins a few rpm's and locks down. The old IR angle one I used professionally for 15+ yrs before the head finally fell off, so I bought an IR to replace the el cheapo.
  17. rustymav1974
    Media Gallery:
    Albums:
    Midland, Texas
    1974 Maverick
    Looked into buying an IR cut-off tool, gonna order one soon. Inectedmav you mentioned spot sand-blasting earlier. I have a sand blaster but what abrasive should I use in it?
