what engine?
Discussion in 'Transmissions' started by hahnmaverick, Mar 22, 2008.
  1. hahnmaverick
    hahnmaverick Member
    pevely, mo
    1970 maverick
    i am wanting to build another engine but dont know what? i have a .040 over 302 kb pistons, scat crank, eagle rods, gt40 heads milled to 58cc with o-rings,air gap intake x303 cam with 9.5 comp. would i be better off putting a procharger p-1sc blow-thru or build a 331 or a 408? i know i would have to change my cam and up grade my carb. for the supercharger:huh:
  2. PaulS
    Build a 331 with a blower - through the hood!
  3. Mavaholic
    I always thought webbers was the coolest looking thing.
  4. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
  5. PaulS
    Sitting on top of a blower!
    Imagine the looks you would get - no matter where you went.
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    If you already have a .40 over 302 block, and there is some wear...you may consider searching for another block. These 302's don't usually do well at .40 and beyond.
    Just my 2 cents.
    Seth
