what flywheel do i use
Discussion in 'General Maverick/Comet' started by 302-72-mav, Jul 10, 2009.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    I am putting a t5 & bell housing in to my 72 maverick and need a flywheel what year car has a 28 oz 157 tooth flywheel or where can i buy one new for cheap
  2. mean_maverick
    nothing is really gonna be cheap unless u find a used one on eBay or just buy an aftermarket one from your local parts house :)
  3. Shinysideup
    Shinysideup Chillin the most
    town
    car
    The 28 oz flywheel also was standard on the 351. BEST to buy a new one for about $65.
  4. pesty351
    pesty351 Member
    Tyndall AFB
    76' Maverick
    What size clutch are you using 10" or 10.5"? If your using a 10" you can use one for a 80-81 stang. For a 10.5" you have to go after market.
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    I got mine from Kajun Enterprises for $140 back in 2004.
    A 157 tooth flywheel is the only thing that is going to fit the stock T5 bellhousing. 164 tooth flywheels are too big.
  6. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    non, no, no... Most, if not all 351s came with the 164 tooth flywheel. I am pretty sure you are correct about them being 28 oz but you don't want to buy a 351 flywheel for a 302 mating it to a T-5.
    I just went through all this with bellhousings. I had the correct flywheel but had a helluva time getting the correct 4 speed toploader bellhousing to mate to my 4 speed and 302, because the 302 need the bellhousing for a 157 tooth flywheel and I bought one and kept finding the bellhousings for the toploader 4 speed but they were for the 164 tooth flywheel that came on the 351 engines.
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    will any 28oz 157 tooth work i am doing a search on kragen.com and i found that 68 and 72 mustang have them does it matter what 302 year it's for and they want like 60$ for them but the core is 80$ so 140 is not that bad but will they fit ? :huh:
  8. 302-72-mav
    302-72-mav Member
    sactown CA
    :burnout:i cant wait
