what front springs are you running???
Discussion in 'General Maverick/Comet' started by sam03rc, Feb 1, 2010.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    rebuilding my front end and this is the last thing i need to buy once my last order of parts comes in. looking at 620lbs fro 67-73 mustangs but what are you guys running???
  2. rayzorsharp
    Running stock 6 cyl springs on mine...uncut
  3. justin has a 74
    kentucky
    Think i have racing springs????
  4. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Stock 6 cyl. 1/2 coil cut.
  5. Bryant
    stock v8 springs with 1.5 coils cut. i will be switching to fox mustang eibach drag springs in the front with some coils cut. wont know how many to cut till they are installed.
    you can get front springs from a fox mustang for cheap and they will fit.
  6. rthomas771
    A stock 6 cylinder with A/C and PS has a stiffer coil spring in a V8 without A/C and PS. The 6 cyl sits on top of the axle whereas a V8 is sitting more to the rear taking the weight with it. A 250 weighs 420 lbs and the V8 is 460 lbs. A/C weighs 61 lbs on a 6 cyl and the front axle sees 64 lbs. A V8 A/C weighs 67 lbs and the axle sees 73 lbs. So saying you have 6 cyl coil springs is saying they could/maybe/possible be stiffer or softer than V8 springs. Ford made 16 different spring rates to use on the Mavericks with different option packages.
    Personally I wouldn't run anything over 350 spring rate if that much on a street car. Anything over that is asking for metal fatigue in the shock tower area or have your teeth shook loose crossing an uneven intersection
  7. bmcdaniel
    Stock 200 cid 6 cylinder springs.
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    all stock v8 and it looks lifted since i added all the aluminum parts.... gonna cut a half coil off probably next month and see how it sits.
  9. scooper77515
    I guess I am the odd guy out.
    Mine are from JC Whitney, and described as "heavy duty". WAY too tall. They held the car up about 6" taller than before. But they are really stiff, which I like.
    I cut 1-1/2 coils off and it dropped to where you see now. I am now able to remove the spring without a compressor, which I really like. Just take the weight off of it, and twist it out.
  10. mean_maverick
    V8 A/C springs in mine with 1 coil removed
  11. justin has a 74
    kentucky
    Just wondering, would a/c springs show a difference?
  12. mean_maverick
    A/C springs have a slightly heavier load rating
  13. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    1969.5 (6 cyl.) springs minus one full coil.
  14. justin has a 74
    kentucky
    Mabey thats why my car was so high??? But still with the v8, it should have been at least level.
  15. mean_maverick
    b4 i cut the coil off, mine set higher in the front than the rear (i guess because i removed all of the A/C stuff and the 40 yrs of wear on the rear leaf springs)
