What headers fit a 302 and C4 with column shift?
Discussion in 'General Maverick/Comet' started by danford1, Mar 25, 2010.
  1. danford1
    danford1 Member
    White Lake, Michigan
    What headers fit a 71 Comet with 302, C4 with column shift and power steering?
    I know this was talked about before but I couldn't find it.
    Full length would be the first choice, but if no one makes any, then I'll go down from there.
    I'm looking for bolt in and go headers if available. I know I will probably have to drop the power steering bracket down. That is no problem as a bolt in bracket can be found...
    Does anyone have any headers for sale ???
    Thanks.
    Danford1
  2. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
  3. danford1
    danford1 Member
    Have you tried them?
    Have you tried them? Do they actually fit?
    I remember awhile back something about a column shift linkage getting in the way. No, this car will not be converted to a floor shifter. The customer wants the column shift as it is.
    I only want to buy ONE set of headers and want it to be the set that works with a C4 and colume shift with Power steering.
    If you personally bought the Summit headers and they fit with a column shift then that is Great ! My search would be over. Did you install these with a column shift linkage?
    Danford1
    PS Here is the Summit info provided: Says No for column shift ...
    MakeMERCURYModelCOMETBeginning Year1971Ending Year1973Engine TypeV8Engine Size5.8L/351Engine FamilyFord small block WindsorEngine SwapNoDrivetrainRWDPower SteeringYesPower BrakesYesAir ConditioningYesStandard Transmission Column ShiftNoStandard Transmission Floor ShiftYesAutomatic Transmission Column ShiftNoAutomatic Transmission Floor ShiftYesFootnotes5 - Can be modified to fit A.I.R. fittings in heads.
    20 - Power steering equipped use bracket BIG-10041 for installation.
    67 - Will NOT fit C6 transmission.
  4. mean_maverick
    The 88400 hedman shorty headers will work (a fellow forum member had them on their car) but i dont know of any long tubes that will work
  5. lilfarley
    Central City, Iowa
    Oh I didn't realize that you can't change from column shift sorry. I seem to recall that maybe doug thorleys shorties were made, but I don't recall if they fit or not.
  6. Dave B
    Doug Thorley's work, but most people don't want to spend the kinda money they sell for. I have them, and they are awesome.
  7. danford1
    danford1 Member
    What is the part number?
    What is the Doug Thorley part number.
    How much are they?
    Danford1
  8. maverick75
  9. GrabberJoe
    GrabberJoe Member
    Brooklyn, Michigan
    1974 Maverick Grabber
    My car has Ford Motorsport full length headers. They were on the car when I bought it. It does have power steering. I was told the headers were very difficult to install but they look excellent. Sorry I don't have a part number.
  10. danford1
    danford1 Member
    Thanks for the info
    Thanks for the info.
    I let the customer decide if he wants the $159 shorties or the $595 shorties ...
    Cheers.
    Danford1
  11. danford1
    danford1 Member
    Good news. Good bye column shift. Hello floor shifter
    Well tonight the deicision was made to go with a cable type floor shifter.
    Now, I need to know what full length headers do not interfer with the left turn radius/pitman arm deal.
    Also, where do I get a different sleeve for the steering column without the PRNDL and shift lever?
    Thanks for the responses.
    Danford1
  12. ladyeclectic79
    ladyeclectic79 Veni, vidi, vici
    Hanford, CA
    A '73 and a '70 Maverick
    Wasn't there a set of Hooker headers that fit? I can't remember the model number though...
