What is 74 OEM alternator output ?
Discussion in 'General Maverick/Comet' started by Powerband, Jul 21, 2019.
  1. Powerband
    Powerband Member
    NY's \H/
    What is the typical OEM alternator output , trying to gauge existing wiring specs':
    Interested in upgrading the alternator in my 74 Maverick (no OEM AC) to 3G one wire setup like on forum threads. '74 Maverick now has 250 Six with Elec. fuel Pump and Elec. Cooling Fan. Planning on adding evacuation pump for boost - blowby (Audi air pump @ 10A ) .
    thanks
  2. Krazy Comet
    Generally 42A & with air 55A. AFAIK there is no difference in the harness for either.
  3. 71gold
    upgrade the alt charge wire...:yup:
  4. Powerband
    Powerband Member
    NY's \H/
    thanks ...
  5. CaptainComet
    Output .... the short answer .... NOT ENOUGH! :p
    Go big! I always hated seeing my headlights dim at idle and then kick back up as you rev the motor.
    BBMS18 likes this.
  6. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I agree.
    Before my V8 even goes in the car, it’s getting fitted with a 130 amp alternator.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    What did you pull that out off, been looking for a power steering setup like that.
  8. BBMS18
    BBMS18 Member
    75 Comet
    The pumps out of a 80-96 Ford E150 van, the bracket is a Borgeson 802409.
    If I was to do it again I would get a GM pump as I had to remove the reservoir and drill a second hole to mount the Ford pump using the Borgeson bracket.
    jasonwthompson likes this.
  9. orig72 grabber
    orig72 grabber Member
    Innisfil, Ontario
    72 Maverick Grabber, 72 Comet GT, 74 Comet GT
    both of my untouched Comets, 72 and 74 have 38A stamped in the housing along with the ford part #
