What is everyone running for motor mounts?
Discussion in 'Drag Racing' started by mgabski, Sep 9, 2016.
  1. mgabski
    mgabski Member
    1973 Maverick
    I am getting ready to swap my motor mounts out. Is there a good aftermarket one that everyone runs or should I go with oem style but put a bolt through it?
  2. mgabski
    mgabski Member
    1973 Maverick
    BTW I know this could go into a different forum part but I figure drag racing is probably putting the most stress on the motor mounts so here would be my best bet
  3. airford1
    airford1 Member
    San Dimas, Ca
    I Ran OEM with a 1/2 bolt thur them in a 4000 lbs Ranchero that ran 11.1 .
  4. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    <<<---------I ran a bolt in my drivers side only up until spring of last year. Worked just fine! Bolt was in use when my avatar pic was taken lol...
  5. mgabski
    mgabski Member
    1973 Maverick
    Looks like that's what im gunna do. Thanks guys.
  6. mav1970
    I used an aluminum engine plate to mount my Cleveland in the chassis :yup:
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Stock rubber OEM. The only ones you need to run a bolt through are the cheap ones made in India.
    The Factory Ford mounts have safety anchors in them.
    Polyurethane mounts are too stiff. The motor needs to move. I've heard of transmissions breaking due to Polyurethane motor mounts.
  8. Acornridgeman
    Acornridgeman MCCI Wisconsin State Rep Moderator
    Wisconsin
    I have the Ford OEM ones in my '72 that have the factory bolt in them.
