What is it?
Discussion in 'Technical' started by rap43, Oct 11, 2004.
  1. rap43
    rap43 Member
    Phoenix, AZ
    74 Maverick 4 door, 73 Maverick 4 door, 76 Maverick 2 door
    On my 1976 Maverick there is a cylinder type device next to the firewall that looks like a vacume tube should be connected to it.
    Anyone know what it is and where the vacume line goes?
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    That is the vacuum reservoir for factory a/c cars. One of the nubs has a line that goes to the manifold for vacuum, and the other line goes inside for the a/c heat selector switch. The "valves"/doors in the a/c vent system are vacuum operated.
    -Corbin
  3. rap43
    rap43 Member
    Phoenix, AZ
    So if I don't have a factory A/C Car it won't work?
  4. Corbin Johnson
    It shouldn't be there if it's not an a/c car. Is it?
    Maybe it is some smog thing I don't know about? I am not familliar with the smog stuff on 74-77 Mavs. What side is it on?
    -Corbin
  5. rap43
    rap43 Member
    Phoenix, AZ
    I believe the car did at one time have factory A/C. It is located on the passenger side next to the firewall. Is this also called the "vacume cannister"?
  6. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    If the car had factory a/c, then the climate controls are vacuum operated. Without the vacuum hooked up to the controls, you will not be able to change where the air comes out, and I believe the default in this case is the defrost vents on the dash.
  7. scooper77515
    I have diagrams for how to re-line the vacuum system on early mavs. I used this on my 74, and was able to replace all vacuum lines, and everything worked wonderfully, until I burned out my Heater fan motor.
    Need scans?
  8. Corbin Johnson
  9. rap43
    rap43 Member
    Phoenix, AZ
    Thanks to all for your help! :bananaman
