What is the yellow box under the radio?
Discussion in 'General Maverick/Comet' started by fullcm, Sep 13, 2017.
  1. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I was installing new carpeting and noticed the yellow box behind the dash under the radio. Looks like some type of electronics or relay, has a harness coming out of it.
    Just curious what it is.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That's the flux capacitor interface
    nidus and CometGTgrabber like this.
  3. fullcm
    fullcm Doug
    Michigan
    74 maverick
    ahha, now I just need to see if she can get up to 88 mph to see it work!
  4. Acornridgeman
    Wisconsin
  5. fullcm
    fullcm Doug
    Michigan
    74 maverick
    ok thats interesting.
    My system is still all there then with overide button in the engine compartment too. However the car starts just fine with or without the belts fastened, I did notice someone unplugged the seat sensors under the seat. Seems strange though that it could be disabled that easily.
    It would be nice to leave it the way it is (disabled) but somehow get the seatbelt warning light to come on momentarily when the key is turned on as a reminder only.
  6. Acornridgeman
    Wisconsin
    I'm not that familiar with the system to know if just unplugging the sensor defeats it, but it would not surprise me. Ford only installed the system to comply with Federal safety mandates. If it was good enough for the Feds - it was good enough for Ford.
  7. Krazy Comet
    I don't think car will start with the seat(s) unplugged, additional mods are required...
    If I remember correctly, the bulletin for disable shows connecting a couple of wires on connector together...
  8. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I'll have to take a look at the override switch and see if the two wires are jumpered as shown in the bulletin diagram that is posted on here, they probably are and maybe the previous owner also unplugged the seat sensors to turn off the light and buzzer as well? Maybe I will plug them back in to see.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
  10. skipsgrabber
    skipsgrabber Should've had wrenches instead of hands
    lower alabama
    1972 maverick grabber,1979 F-150 4x4,1957 Studebaker Silver Hawk,1942 Ford Coupe,a boat,39 JD "H",And a bunch of JD garden tractors
    My 78 Mustang II had that interlock,became an issue later on... There was evidence of wire cutters and electrical tape,but it was understandable,t-top car with velour seats = fried electrics... Good luck
  11. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    My 74 maverick would run with out it. Hasn't affected the performance any.
