What is this thing called? (Power Steering Question)
Discussion in 'Technical' started by Jeff S, Apr 6, 2009.
  1. Jeff S
    Jeff S Member
    NoVA
    none
    I have a lot of play in the steering wheel, and I went to search to where the problem was and found this...
    You have the steering column that goes down into the steering box, then you have the pitman arm that comes off of that and goes into another box at the end of it, theres Im assuming a bushing in that 2nd box that has gone bad, because thats where the play is coming from...it has 2 power steering hoses coming from it and its located right behind the driver side wheel, it actually sticks out from the wheel well and can be seen from the outside if the wheel is turned all the way to the right.
    The car has power steering, and Ive taken it to 3 shops and none of the mechanics has ever seen that.
    If anyone has any good spares laying around Ill be willing to buy.
  2. Bryant
    that is the controle valvl for power stearing. now when the motor is off there will be excesive slop in it. when you turn on the motor the system pressurizes and that slop get reduced signifacantly.
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    also by the way, go to a different shop because any old ford mechanic has seen that.
  4. Jeff S
    Jeff S Member
    NoVA
    none
    theres a lot of slack in it when driving also, I have to turn the wheel about 1/6th of a turn before it starts responding...is that normal?
  5. Thack
    Thack vision advicator
    Moreno Valley Ca
  6. sierra grabber
    northern nevada
    that sounds more like the gear box has slack.
  7. blugene
    That's what i'm thinking...
  8. darren
    My guess is they just no better than to work on it. I use that excuse when I can get away with it. :rofl:
    Seriously, if you brought it into our shop myself and one other old guy would know what we are looking at. Thats ancient technology and not many guys out there have worked on that system. It was a pain in the ass back then. I say get rid of it and go manual.
  9. Jeff S
    Jeff S Member
    NoVA
    none
    I had someone turn the wheel while the car was both running and off and the pitman arm has immediate response to the slightest turn, its when it gets to that second box that theres slack, you can see the pitman arm going left and right about 1/4-1/2 inch on either side before any resistance is encountered.
  10. Jeff S
    Jeff S Member
    NoVA
    none
    Im seriously thinking about converting it to manual...the less stuff I have the less stuff that can break...how do I do it the RIGHT way....people keeps telling me different things....
  11. phree_man
    phree_man Member
    Lancaster, CA
    1974 Ford Maverick 2 door
    so if it is gearbox slack, how do I fix it because I think that's what I have going on. and it sure would be nice to be able to fix it.
  12. sierra grabber
    northern nevada
    search the forum for adding a grease fitting to the gearbox. following the steps should adjust out the slack, lube it and give you a place to lube it from later. it works great.
