What is this?
Discussion in 'Technical' started by PAINTANK, Nov 20, 2009.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    It was n't ouching anything and seemed to have no purpose. I noticed the bracket it is on was bent so I straightened it out and it touches the "thumb place" on my throttle linkage so I determined it must belong there. I noticed it got stiff when the car was running and increased my idle. Is this some sort of idle control thing? The dizzy wires are in the same bundle as the red wire that this THING is plugged into. When I unplugged it the car stuttered momentarily but kept running fine. It is probably some sort of first day automotive class thing I should already know right?
  2. PaulS
    That is your "curb idle solenoid".
    It is used to hold the idle high enough that the car won't stall at stops but disengages when the key is off so the engine doesn't run on (diesel) when you shut it off.
    I tune the engine to the lowest idle in neutral and then set the curb idle in Drive as low as I can without suffering from stalls. It works better for me than having the engine idle at 700 in gear.
  3. PAINTANK
    1973 Comet 2 dr
    So I bent the bracket holding it in place and set it so when the car is idling in drive it's around 700rpms(with the solenoid at "full mast")
    It was bent all the way out of the way.
  4. Blown 5.0
    MS.
    1974 Maverick
    On mine it was for the AC high idle solenoid.
  5. Dave B
    That's what I was thinking, I've only had them on cars with A/C...
  6. PAINTANK
    1973 Comet 2 dr
    Soooo I can go ahead and remove it and it won't mess up my fly ride?
  7. darren
    You should be OK to remove it but it does work well for stopping run on in the hot weather when its set up right. IF it was my car I would use it and have used them in the past.
  8. PAINTANK
    1973 Comet 2 dr
    Neato. That's less work for moi.
  9. 71gold
    that's what mine is...:Handshake
    ...:cool:...
  10. justin has a 74
    kentucky
    Ive never messed with it but it sounds like you can set the idle lower? cool, i need to put mine back on, i want to hit 400 like scooper.
  11. PAINTANK
    1973 Comet 2 dr
    I set mine halfway between 500 and 1000.
    700 is what I'd guess.
  12. justin has a 74
    kentucky
    600 gives me a good lobe, paintank! put a cam in the comet!
  13. Jamie Miles
    I tossed that thing in the trash eons ago.
  14. mean_maverick
    ive had two '73 302 cars that were non-a/c that had those (one of them being my 4dr, the other was a '73 Grabber 302/3sp manual)
  15. PAINTANK
    1973 Comet 2 dr
    Eventually I'll get one when I feel confident enough to install it and all the stuff that it entails. First the electronic ignition, then the 4 bbl, then the headers...
    So ditch this lil guy or keep it? If I don't need it then why keep it?
