what motor?
Discussion in 'New Members Forum' started by 37788mav, Jul 28, 2013.
  1. 37788mav
    37788mav Member
    south carolina
    1970 maverick,1959 vw
    how can i tell what inline 6 is in my car? vin says 250 but you no how that go's.its a 1970 maverick.
  2. Krazy Comet
    I believe easiest way is position of starter... If it's down by the oil pan rail then you have a 250, the 170 & 200 mount higher approx midway on side of engine... There are other differences but I'm not totally familiar with the 6cyl...
  3. 37788mav
    37788mav Member
    south carolina
    so if i want to install a v8 do i just change bell housings?is there any numbers on the motor that i can decode?
  4. Krazy Comet
    The bell for a 250 is same as 302, the smaller six are different(at least part of the reason the starter is higher)...
  5. 37788mav
    37788mav Member
    south carolina
    just went and checked.the starter is down by the oil pan rail.
  6. rthomas771
    Count the water pump bolts. 250 has 4 bolts and 170-200 used 3 bolts. 1980-83 200's have a low mount starter.
