What oil after first oil change after rebuild?
Discussion in 'Technical' started by gdemopesq, May 25, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I am ready for my first oil change. I used diesel spec oil for a few hundred miles. What should I use now on my first change?
  2. Comet155
    Comet155 Member
    Any decent multi grade appropriate to your temperature range should be fine.
  3. don graham
    I usually just run a 10-40 wt, but whatever they say for your area.:)
  4. PaulS
    Any good 10w-30 to 20w-50 depending on bearing clearances, temperature extreems, and personal preference. Try to use an oil that is easily and always available in your area so you don't switch araound a lot.
