It doesn't seem the headers I got will fit without taking out the power steering. Whats the easiest way to convert it to manual steer? Unless someone has a trick to make my headers work. (6901's)
Header fitment requires a power steering drop bracket.You can get it from Autokrafters or I believe Summit/jegs has them.The change over isnt hard either if you really want to go to manual steering,but it isnt necessary for header fitment,just get the drop bracket.
All you need is a manual drag link and pitman arm. Both are available from Autozone.com. Both are mfg by "Rare parts" The drag link is P/N 25881 ($122) and the pitman arm is P/N 20130 ($91). Remove all the P/S stuff , remove the P/S pitman arm and bolt the new stuff in place.
All you need is THIS...http://mmb.maverick.to/showthread.php?t=40493 Just popped up a few minutes ago. That is EXACTLY what I bought. Worked great, and got rid of all those leaky hoses... It is pick-up only, but as close as you are, it might be worth the drive.
