what procedure for fuel pump install on 302
Discussion in 'General Maverick/Comet' started by Flamesoldier, May 5, 2009.
  1. Flamesoldier
    Flamesoldier Member
    1973 Ford Maverick 302
    I believe I have a bad fuel pump. I am receiving fuel to carb but fuel pump blew some oil out a small hole on side of fuel pump and sprayed outside of oil filter. Anyway how does one install one is it as simple as gasket and bolt up or what?
  2. Mavman72
    Pretty much a bolt on deal...If it wont slip in place without some force behind it.Bump the engine over to rotate the fuel pum eccentric away from the pump arm so it mounts without having to force it in place and draw it on with the bolts.
  3. Mercurycruizers
    Venetia, PA
    Just make sure you put your finger up there, to hold the shaft while putting the pump on. Then tighten the 2 bolts & your done....
    Been there, done that....
  4. 71gold
    :hmmm:..what shaft is this....(CHEBY)
    ...:rolleyes:...
  5. Mercurycruizers
    Venetia, PA
    Duh! I guess it was a Cheby. I had a 69 Z-28 for 14 years. Then found the Maverick/Comet 10 years after I sold it.... Must be old age....:rofl2:
  6. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
    hello mavman, how do i know if my eccentric is bad. I took the fuel pump off because i thought i had a bad fuel pump, i stuck my finger in there and i can turn the eccentric with my finger. Is that bad? how do i fix it? or is it possibly just the fuel pump.
  7. justin has a 74
    kentucky
    Im thinking oil pressure plug, tighten that plug up.
  8. PaulS
    You might want to put a pressure gauge onit before you replace it - all it takes is 6 psi -8 psi. Shouldn't bleed down once you have pressure.
  9. monstermav
    monstermav Member
    utah
    77 maverick 4dr 351
    "i stuck my finger in there and i can turn the eccentric with my finger. Is that bad?"
    Your eccentric isn't bad, it has a roller kind of thing on it to reduce friction.
  10. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
    Hello pardon my ignorance but were is the oil pressure plug? i dont know much about cars, im learning as i go with this little maverick project. I do appreciate your reply's though thank you very much.
  11. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
    thanks for the reply. The old fuel pump i had was a holley 80 gph and i literally ran the car five miles with it and then parked it for about a year. Im replacing it with a carter 120 gph mechanical pump. I have a 302 with a 650 edelbrock carb and a moderate intake manifold and headers. Nothing major. Will the carter be ok?
  12. monstermav
    monstermav Member
    utah
    77 maverick 4dr 351
    The old fuel pump i had was a holley 80 gph and i literally ran the car five miles with it and then parked it for about a year. Im replacing it with a carter 120 gph mechanical pump. I have a 302 with a 650 edelbrock carb and a moderate intake manifold and headers. Nothing major. Will the carter be ok?[/QUOTE]
    I would use a fuel pressure regulator on a bigger pump.
  13. rthomas771
    Never seen one that had rollers. If the eccentric is moving then it's about to fall off
  14. Bryant
    some of the ecentrics have a sleve that rides around it. im sure that is what he is feeling.
  15. monstermav
    monstermav Member
    utah
    77 maverick 4dr 351
    ya, you can see it in that picture he posted.
