What Radiator should i put in my 302? 73
Discussion in 'Technical' started by CentralValleyComet, Jun 18, 2012.
  1. CentralValleyComet
    CentralValleyComet Member
    West Coast
    73' Comet 302 4-Door
    I know how to install and I already took old one out.
    So Should I just buy an alum or copper? 1/2/3 rows?
    Also should I just referb orig? It cost 75.
    around 150/220 for new one.
    Help me out guys thanks
    and also I cut my trany line on the bottom to radiator I bought a copper line (ya i know) but I should put in the metal one instead?
    Its going to cost me to get that new line in metal. im not sure how much.
    thanks
  2. Craig Selvey
    For $75 I would probably get the old one referbed. That is not a bad price.
    If you want, you can get new tranny lines, pre-bent, from www.RightStuffDetailing.com
  3. 71gold
    referb. if the radiator can take it...if they have to...recore, a new one would be better...:Handshake
  4. Mercurycruizers
    Venetia, PA
    I just had the radiator done in my 70 Maverick 302. It is a 3 core factory. I couldn't fine a new one anywhere, price was $340. Had to get it recored for $380. Had it back in 2 days. The guy said he would put it up against any aluminum radiator & it would cool better, plus it's the original radiator that came with the 302. Glad I got it done & it's original & new. My choice to stay with stock & not go aluminum.
  5. 71gold
    I checked with my Guy at Advance Auto parts...3 row....$203...my cost $149.
    I've bought these for myself and others over the years...it will have to be ordered...
    ...:thumbs2:...
  6. CentralValleyComet
    West Coast
    thanks. I Took in the orig. Now I just need my t-line fixed. I heard rubber but I would like to get steel tubing if I can find it.
  7. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    The three core aluminum from Champion does an excellent job of cooling, but is a really tight fit.
  8. CentralValleyComet
    West Coast
    transmission line. can I use the T'Lines off a 1972 comet?
    I found some for 60$ for both.. They are pre/bent though so it has to be an exact fit>?
  9. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    Did the 72' Comet have a V8? Also, if you have headers and the 72' did not you may have problems. I found out the hard way. :)
  10. CentralValleyComet
    West Coast
    I think 1974 is when they stoped making the v8.
  11. FordCountry180
    Parkesburg, PA
    72' comet had 4 engine options 170 200 250 302. Are the tranny lines from a 72 comet V8?
  12. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    I need one witch side does the lower rad. Hose come on mine its the passenger side
  13. olerodder
    olerodder Member
    NorCal
    Since I am buying one, can you define what you mean by "Tight Fit", or better yet send some pictures.
  14. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    The drain petcock hits the front cross member. Several of us had to notch the crossmember for clearance. The bottom radiator hose JUST clears the cross member when installed on the radiator outlet. The radiator cap is probably pretty close to the hood but doesn't touch. But, you'll love it.
  15. 71gold
    talk to Sid at Champion. tell him it's for a Maverick...:thumbs2:
    951-245-9464
