what size converter
Discussion in 'Technical' started by JHodges, Apr 5, 2010.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I was looking on ptc site and they will build an 11 inch converter for $275. I was wondering if that would work in a big bell c4. The techs were on lunch when I called
  2. mean_maverick
    If youre using a small bellhousing (157t) you'll need a 10" converter
  3. 71gold
    will it work with your motor?
  4. Blown 5.0
    MS.
    1974 Maverick
    This is not true, I run a 11 inch now. My previous was a 12 inch. Although the studs have to be lined up before the trans is all the way in. Because There is no room for it to slide back into the bellhousing. You do have to run the 10.5 or 10 inch(cant remember but its the small bolt circle) bolt circle converter with the 157 tooth flywheel.
  5. JHodges
    JHodges thumper
    Dora Alabama
    I am running a 164 tooth flexplate. He reccommended the 10 inch converter so I plan on going with that
  6. JHodges
    JHodges thumper
    Dora Alabama
    A guy on yellow bullet has the converter they reccommended for my setup. He wants $200 for it so I am going to try and guy it in a week or so
