What Springs to use?
Discussion in 'Transmissions' started by Bigsmo92, Jul 6, 2011.
  1. Bigsmo92
    Bigsmo92 Member
    Robinson, IL
    1975 Ford Maverick
    I'm finally getting ready to swap my C4 Transmission with a 4 speed. I have everything but the springs that are required. Can somebody lead me in the right direction? I have looked on Mustang Unlimiteds websight, but there are several different spring and want to make sure I get the right ones. The only spring I have is the Blue one on the pedal assembly, but I'll probably replace it also. Any help would be appreciated.
    Thanks, Mike
  2. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Bigsmo92, are you going to use a clutch cable, hydraulic throwout bearing or the z-bar type. I went with the cable and do not use a pedal spring.
    Ken
  3. bmcdaniel
    Using a z-bar here, I removed the big blue spring when I went to a diaphram clutch and have a spring from the release lever to the shock tower that I picked up at Lowes, LOL.
  4. Bigsmo92
    Bigsmo92 Member
    Robinson, IL
    1975 Ford Maverick
    Thanks Guys,
    I have the old springs. I'm just going to take them in to our machine shop at work and match them up as close as I can.
    Thanks again for the responses, Mike
