what tire size for stock car
Discussion in 'Technical' started by 72 maverick, May 13, 2007.
  1. 72 maverick
    72 maverick Member
    1972 four door 302
    72 four door, 302 manual steering. It has 185-75/14 on it now. Should i stick with that size? or go to sumthin different???
    later!!! chris
  2. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    My car has a 302 with manual steering and i have 205 75 14's in front and 215 75 14's rear.I think the fill the wheelwells pretty good and it steers fine.Also rides better with the taller sidewall tires.
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Those are much too wide for a stock 4-1/2" wheel. The stock size was the equivalent of a 185/70-14 (D70-14 or C-78-14)...
  4. Derek 5oComet
    I only have the 4 1/2 wheels up front, sorry forgot to metion that the rears are 14x7 1971 MACH 1 wheels.
  5. T.L.
    T.L. Banned
    Southern Colorado
    Well you can run a 235/60-14 on a 7-inch wheel. You can actually run a 245, but I don't like how the sidewalls tuck inward...
  6. grbmaverickmo
    Aquashicola, PA
    205/70-14 on 4.5 frt and 245/60-14 on 7`s in back worked on mine
  7. T.L.
    T.L. Banned
    Southern Colorado
    4.5" rim is too narrow for a 205/70-14...
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    72s used 6" wide rims...
    At least the 5 lugs anyway.
    I have 245/60/14s on my stock 6" rims.
    Both my Mavs, and for MANY years.
    I don't know what Mavs came with 4.5" rims, but I suspect they are either very early models or 170 powered cars.
    Personally I have never owned a Maverick with anything less than 6" wide rims.
    Dave
  9. ratio411
    ratio411 Member
    Pensacola
    I generally use 215/70/14 up front because they appear the same height as the rears. Make a good match for the front.
    The fronts in this pic are 205s... A little shorter than the 245s out back.
  10. T.L.
    T.L. Banned
    Southern Colorado
    My '73 came with 4.5-inch wheels. I imagine that only Grabbers came with 6-inch, but I don't know that to be a fact...
  11. Craig Selvey
    I have found Mavericks with 4.5" and 6" wide wheels. 2-doors, 4-doors, Grabbers.....no real rhyme or reason to it.
  12. ratio411
    ratio411 Member
    Pensacola
    :huh:
    Weird.
    I have had 2 Sprints, 72 Grabber, and 75 2 door...
    All had 2 doors, V8s, and 6" rims.
    I knew some had 4.5", but I figured it was a 70 only thing, or small I6 thing...
    Now I want some 4.5" 5 lug rims!
    They would be good on front.
    Nah, second thought, I want to get away from 14" rims...
  13. Craig Selvey
    I have 4.5" wheels......even disc brake versions.
