What to call this ....?
Discussion in 'General Maverick/Comet' started by Russ, Jul 21, 2004.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Either, This is what you do when you're bored, or The Bruiser took a shot to the nose. Found some rust under the what's left of the battery box. Time to get a welder...
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Very common problem on most cars.
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    the bruisers nose took a hit? what happened?
    -Todd:)
  4. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    I attacked it! Time for a little R&R (Russ and Rust). I found the rust so I figured might as well put the new fenders on while I'm here. I got the pass fender off tonight and will try to work on the drivers side tomarrow. I have a extra front clip here with a diecent battery section in it so after I get it apart,I'll cut it out and have a friend weld the patch back in. Now all I need is the battery tray itself. :rolleyes: After I get the 2 door back together, I'll attack the 4 door. It needs a new exhaust and a heater core(Oh goodie). The fenders that I'm taking off the 2 door will make their way to the 4 door. Kind of like hand me downs. They're not perfect but they're better than what's there now. Russ
  5. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Russ & Rust. lol
