what torqe converter
Discussion in 'Drag Racing' started by HOMERMAV, Jan 12, 2011.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    im in the market for a new converter 3200-3500 range any thoughts.and does anyone know anything about boss hog converters?
    thanks john
  2. anytakers
    anytakers Member
    Wytheville VA
    1972 maverick grabber
    how much money you wanting to spend on one?
  3. PaulS
    John, how did you come up with 3200 - 3500 rpm range?
    Is this for a track only or a street car?
    What kind of power do you have?
    How much does your car weigh? (with driver)
  4. 71gold
    these and other answers need to be given to a...converter company...:tiphat:
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    paul my cam has a 3000 to 6500 rpm range motor will be around 425 hp and car weight is 2900 with me in it.hughes performance just got back to me and said i need a 4000 stall with all the info i gave them. seems a little high but there the experts. so i will be going with a hughes 41-40.
    thanks john
    P.S. paul it is a strip only car
  6. mercgt73
    mercgt73 Member
    :thumbs2:
    Unless off the shelf is what you want... but I think converters need to be matched to your vehicle, you will be much happier with the results.
  7. 71gold
    :hmmm:...you still need to know what stall you need...
    call converter company...give them the specs.... get their opnion and then buy...off the shelf...:huh:
    been there, done that...:tiphat:
  8. mercgt73
    mercgt73 Member
    You can still guess and the car will move forward when you accelerate.
  9. don graham
    I have a Hughes 4500 in mine. I'm happy with it.
    I've also got 2 of their 3500 convertors. :)
  10. mercgt73
    mercgt73 Member
    Cool! Your setup is similar to my Mustang II, 351W 400hp, 2800 lbs with driver. Ive got an 8" TCI, which was made after I gave them all my specs. I think Im a 3800 stall. I picked up close to half a second coming down from a 10" street converter.
  11. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    don sent you a pm
  12. JHodges
    JHodges thumper
    Dora Alabama
    I bought a redneck performance 4500 stall for the glide in the mustang. It should be back together in a couple weeks and I will tell you my opinion of it
  13. 1badmav
    1badmav Member
    PTC enough said...
  14. 71gold
  15. PaulS
    4000 rpm stall is probably close for a strip only vehicle - you might be better off with a bit more but try the 4000 first. My guess is that it will not stall to 4000 but somewhere between 3000 and 3500. You probably aren't getting peak torque before 4500 rpm anyway.
